Beovision MX4000 or MX4002
Can someone explain the difference between the MX4000 and the MX4002? The website says:
  Beovision MX 4002 was the Beolink® variation of the
Main diff is age and the fact that you can remote control an Avant/DVD/VCR in the main room if the MX4002 is connected with the Avant through RF- out on the Avant.
You can still listen to music in the MX4000 if it is connected to a MCL2AV
So does that mean that the 4002 is superior to the 4000, or does the 4000 have an advantage in some other area?
 Mark
No
Um...
There were two questions in that sentence. Which one is "no"?
Mark
MX4002 is better
There seems to be some confusion here!
The 4002 is a later version of the 4000. The difference is that the 4002 has MASTERLINK
Oh i was gonna say, go for the 4200, it has a flat screen was similar to the BeoVision 1 🙂
The 4200 has the Beovision 1 chassis with a smaller screen. It has a picture quality to die for. Much more expensive than 4000/4002
Hi!MX 4002 was the Beolink Version of the MX 4000. It was designed as a Link-Room-TV. They have a Masterlink (ML) connection built in. The MX 4000 was designed as a Main-Room (but can`t work as a master like the Avant or AV9000)  or stand-alone TV. As an option you can fit it with an Satellite-modul! That`s not possible with the 4002!!! You can use the 4000 for a Link-Room, too. All you need is an Datalink-Masterlink converter.   So, if you are looking for a link-Tv choose the 4002. But if you need a satellite-modul it`s better to choose the 4000Sat with a converter!As a Main-Tv or stand-alone Version only a 4000 or 4200 (latest version of the 4000Series) will be the correct choise!GreetsChris
