Can someone explain the difference between the MX4000 and the MX4002? The website says:
Beovision MX 4002 was the Beolink® variation of the
Main diff is age and the fact that you can remote control an Avant/DVD/VCR in the main room if the MX4002 is connected with the Avant through RF- out on the Avant.
You can still listen to music in the MX4000 if it is connected to a MCL2AV
So does that mean that the 4002 is superior to the 4000, or does the 4000 have an advantage in some other area?
Mark
There seems to be some confusion here!
The 4002 is a later version of the 4000. The difference is that the 4002 has MASTERLINK
The 4200 has the Beovision 1 chassis with a smaller screen. It has a picture quality to die for. Much more expensive than 4000/4002
