Beovision mx 3000 turn on volume problem
Hi
This is my first post here, I hope i will not sound too funny with my problem
I just got third-fourth hand mx 3000 with ASWO 3216 remote
It works great, but when I turn it on, volume is loud, about half scale
It's a problem at night, i have to mute it the moment i turn it on
How to fix this?
How to acess service menu?
Welcome to Beoworld!
You mean you don't have a B&O remote for it? (Beolink 1000 or newer). The syntax for storing the sound settings is: set volume to preferred level and then press STORE - SOUND - STORE. Don't know about other remotes, though.
The user manual is available on the site for bronze or golden members.
I dont have beolink, but this is a good replacement, so i figure that will work
Thanks for ansver and for welcome note
You're welcome! 🤒
If the replacement remote is for B&O it should have all the required buttons. It will be far from the Beolink 1000 in terms of quality, though!
By pressing SOUND you can access the treble, bass and balance adjustments, too. Color and other settings are found under PICTURE, and when you are happy with the settings, STORE-PICTURE-STORE.
