Beovision horizon
I just can’t believe people tolerate this false advertising by B&O. Functionalities that never come to life, misguided buyers over nonfulfilled promises on corporate website etc.
Isn’t there a customer protection law in the EU that regulates it?
Another week went by and still no update for the BV14 / Horizon...Really want to use full Multiroom support finally after 1y promises...
What part of Multiroom doesn't work?  You mention that you want to use "full Multiroom".  Just curious as I'm cautiously considering an Horizon and multiroom is one of the main drivers.
Thanks,
Stan
Thanks,
Stan
That is correct, the TV works fine in Multiroom setup but is not fully supported by the new app. No functionality missing but it is handy if Horizon acts the same as the other products. and I want the icon to be present in the app 🙂
That’s not a Horizon limitation, it’s a limitation in the app, right?
What I have understood is that the Horizon software needs to be activated for this function. But not 100% sure.
I am in the beta group for the app and I was told that the app team was waiting on the go from the tv tean.
So where are we about the software bug on beovision horizon and eclipse?
Will it be a new TV soon?
Thanks.
I'm planning to change my 2010 BeoVision 10-40" for a new TV.
BV Avant, 14 and Eclipse are unfortunatly too expensive -:(
And if there are new BV in the pipeline (or new panels in the current line), i think it will be expensive too...
What do you think about a 48" BeoVision Horizon ? A good choice ?
