BEOVISION ECLIPSE
I stayed with my Avant Mk 1
TEL
AdamsS
How's the 65 inch Eclipse?
I've today ordered a 55 inch Eclipse
TEL
I have an Eclipse 65 and are very happy with it. I have not found any shortcommings at all with this TV.
The software is very stable!. You vill enjoy Your 55-inch Eclipse very much.
Good luck!
Best Regards
My friend and i installed my new eclipse 55 Bronze today. Pretty happy with it :)
I love your ceiling and room in general, looks really nice!
Awesome install. No cables 🤒
Thank you guys.
I have some problems controling my TV STB.
When i installed the Apple tv 4k i just choosed the apple tv 4th gen and it worked directly without any puc cables.
My STB Is a Motorola/Arris VIP 4302 from Telia. and its also Bluethoot controlled. Was thinking maybe it can also control ther STB thru BT but that seems not the case.
Got a Puc cable from my dealer today, My STB was not in the PUC list but played around and tried several Motorola VIP codes incuding generic.
None working. Anyone have any idea what to do?
TEL wrote:
AdamsS
Generally, we love it. The picture is superb, the wireless interface with the BL90s and the rest of our stuff is faultless and it performs brilliantly. As an aside, the installation service from our dealer was superb and included hiding the cables inside the wall and re-plastering it. Very impressed!
Normal 0 false false false EN-GB X-NONE X-NONE
However, it has one weird issue that we, our B&O dealer and B&O Technical are struggling with - basically, sometimes it just won't switch off!
What happens when you press power off on the BeoRemote One is that the speakers all switch off, the picture shuts off and the Eclipse starts to fold back against the wall. However, when it gets about halfway, the ‘Bang & Olufsen’ logo appears on the screen for ten seconds or so, then goes away. Then, when the unit is flush to the wall, the logo appears once again for another fifteen seconds or so, and then whatever we were last watching reappears – if it was Live TV, the channel we were previously viewing comes back, or if it was our Humax box, then the “No Signal “ message is displayed, as the Eclipse has obviously switched the Humax box off. There is no sound, the speakers do not switch on, it does not respond to the Beoremote One or the app, and the app says that the Eclipse is in standby, but the picture is there and nothing can be done about it.
As a result, I'd been having to switch the set off at the plug every night and this, in turn, made it keep losing settings and generally behaving badly sometimes when re-started!
After some investigation, B&O Technical suggested it might be due to the internet connection and, if I pull out the lead to our home hub, it does indeed switch off properly. However, about two weeks ago in the middle of all this, we were sent a new hub by our broadband supplier and, with this installed, the Eclipse now does mostly swtch off correctly, but it still shows the 'Bang & Olufsen' logo as it shuts down, which it apparently shouldn't do.
I need to go back to the dealer again as I said I'd run it with the new hub for a couple of weeks to see how it behaved and, as it's a known issue (albeit a rare one), hopefully they'll be able to sort it once and for all.
I got a new Eclipse 55 last week and I’m working on the sound settings right now.
On my BV11-40 I can select “Adaptive” sound mode so that sound mode changes based on meta data in the TV channel.
However I cannot see this option on the Eclipse. Only “static” sound modes like “film”, “music” etc. can be selected.
Am I missing something or is “Adaptive” sound mode not present (yet) ?
Best regards
Dyssegaard
On my request to B&O support regarding adaptive sound mode, I have received the following reply (in danish):
“Denne funktion er desværre ikke mulig længere. Vi var nødt til at ændre på hvordan vi laver vores tv så de blev lettere og mere standardiseret at bruge. det har så betydet at vi ikke har helt så meget kontrol over softwaren der bliver brugt. Vi vil selvfølgelig give dit ønske videre til vores hovedkontor. Hvis vi formår at få funktionen tilbage vil vi selvfølgelig informere således”
In short: This function is no longer possible due to the way we produce our tvs now. We do not have so much control over the sw any more. We have forwarded you request to our headquarter, and we will inform you, if we are able to get this functionality back ...
Best regards
Dyssegaard
