BEOVISION ECLIPSE
Hallo Fidse,
I have put my Apple TV inside the plastic part of the ECLIPSE,
Rock steady wifi no problem.
The LG wifi is rubbish, had the same problem on my C7 65" and the internet is filled with the problem on forums.
My Eclipse turn directly on to Apple TV, I never use the built in streaming.
Aarh yes, of course. It’s in the plastic part and not inside the actual soundcentre. Silly me😁
Thanks Emil
Funny enough i’ve never had any wifi (or any other, for that matter) problems with my C7 or my B6. The Eclipse on the other hand is a wifi nightmare.
Emil Jensen wrote:
Hallo Fidse,
Ive contacted my BeO dealer 1.5 years ago about the wifi issue. Its so unstable that I really cant use any IP-TV services at all.
Do you know if its hardware related or SW?
my BV14 was the same.- awful Wifi, while other devices right next to it were downloading at 70-100MBS.
Something about the wifi hardware in these TV's.
Hard wire the Eclipse - costs little, headache over.
Nothing quite screams premium lifestyle brand like poor WiFi hardware, something everyone else has been able to do right for years now.
Not that it is any excuse, but it is related to the LG hardware I think,
I cannot find any solution for it.
The soundcenter part fine for me, with airplay, radio and so on.
For streaming as I said I use Apple TV,
So I don't notice it in the daily use,
But yes it should not be the case.
Did anyone try 2.4 band instead of the 5ghz.
Sometimes works better. Just a suggestion, no idea if it works.
Ive tried the 5 Ghz and 2,4. Also hardwired it but get drop-outs with that aswell. Apple TV runs fine on wifi.
Need to have a stable wifi/ethernet on the TV itself because of the iptv software Im running.
Is this an issue for the earlier versions only?
My TV is hardwired to the router, no problems.
Do you have a hard disk connected?
Please do not take a USB extension, then there may be picture dropouts or the picture freezes.
This was the problem in my case.
Ingo
Set a fixed IP in the router? Helped with my beosound 1.
