BEOVISION ECLIPSE
Emil Jensen wrote:
and one for Live tv,
since the previous update, you can program the Eclipse to start Live TV by simply press the TV button on your remote (at least for start up)
Hallo Carolpa,
Thank you, actually I enjoy this very much already but I have Apple TV as my first choice as 90% tv watching is streaming for me.
Great update - and I agree, can’t wait for the curtains 😁
Only thing is when I try and open the home control overlay it asks me to login to my BLGW. The cursor is in the password box but I appear to have no way of getting to the username box!!! So can’t login.
Oh and I also I got my HDMI port update installed today - will let you know how it is with my Apple TV in Dolby Vision (but immediately seems better).
Chris Hassell wrote:
Oh and I also I got my HDMI port update installed today - will let you know how it is with my Apple TV in Dolby Vision (but immediately seems better). BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
I also had this updated but my 4K hdmi 2.0 cable does not work is there a particular brand or spec that I need to buy?
Vince
Only thing is when I try and open the home control overlay it asks me to login to my BLGW. The cursor is in the password box but I appear to have no way of getting to the username box!!! So can’t login. BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Hi Chris
I had the same issue so I used the LG TV Plus app which has a cursor feature and you’re then able to move it up to username. Hope that helps you out.
Regards
Stuart
Ealing.
Hi Chris
Regards
Stuart
Ealing.
You need a blgw update to adjust this login issue.
So I've been on standby for a new Eclipse for a while now. I told my dealer I was only interested in the model with the newer 2018 screen. After months of waiting he said they were now delivering the new screens and we set up an installation date. When the screen was delivered to the dealer I asked him to check it was a C8. He took a photo of the B&O label on the outside of the box: "OLED65C7BO" so clearly not a C8 screen. Installation cancelled. Now he says that it is unknown when the new screens will come.
Can anybody here say whether they have received a C8 screen yet? In either 55 or 65 size?
Copied from the thread of my review of Eclipse on FlatpanelsDK, where I have written the following:
There has been some speculation about the possibility of upgrading Eclipse with a newer panel or that
Eclipse should be updated from the B & Os page to include a 2018 panel. From a reliable source we have that
Eclipse will not be updated neither this year nor next year. The cost of letting LG rebuild a new one model to fit
in Eclipse both hardware and software is simply too big for it to pay themselves. In addition, it is estimated that
the changes from C7 to C8 are too small to make the user a significant partIt (our own tests confirm the marginal
improvement). B & O must have secured a sufficiently large amount of money Lot C7 to continue into next year.
/ Torben Rasmussen FlatpanelsDK
link
Apple 4K TV recommends it's Belkin ultra fast cable.
It works since the hardware upgrade
