BEOVISION ECLIPSE
How to see when Your Eclipse has been produced?
Does Netflix and or amazon work on the Eclipse?  Seeing it has a button
Yup, works like a charm. Dolby Vision and everything 👍🏻
Does anyone knows when the 04.70.90 update for the C7 panel will arrive to the Eclipse? Getting tired of the true motion. Much better in the latest release from LG.
For those wanting to know if this has been incorporated in their sound centre:
To get the newer hardware version of the Eclipse with improved HDMI 4k Dolby Vision / HDR support, you need to supply
BeoVision Eclipse SoundCenters produced after mid-February 2018, with serial number higher than 55” 29528201, and 65” 29303824.
Hi, new software update yesterday 2.1.xxxxxxxxxx.
My Buttons works Now!!!!
good work B&O. Now Eclipse is working perfectly. Even Beolink Gateway is now compatible with the Eclipse.
Best Regards
Gateway ? Or BLC NL/ML Converter ??
I got the same feedback from my dealer. Does this mean that the serial numbers below the mentioned numbers should not have any HDMI 4K Dolby Vision/HDR issues? Or does this mean they will keep limited support?
My Beovision 55" has a serial number below the mentioned number and does give problems when I setup the apple tv to automatic mode. But it does work fine if I put the appleTV settings to 4K, 50Hz, Chroma 4:2:0 and switch to Dolby Vision after that. If I select any higher modes the system is not reliable (picture lost occasionally). Any other experiences on this for serial numbers below the mentioned ones?
Regards,
Dennis
Eclipse getting more and more Beo-ish!!:-)
Now its just the curtin left!!
Great, now I can get it to the other position with only one push of a button, that is really user friendly.
Now I have to figure out what to use the other 3 my buttons for :D
I guess one for Playstation and one for Live tv, then there is one left.
What a great Television
