BEOVISION ECLIPSE
Millemissen wrote:
Marcello wrote:
Anyway I will visit my dealer with a DTSHD file and see for myself the result.
Oh - there we go....a file, not a disc ;-)
I am pretty sure, that if you play that back directly via the LG’tv-part, you will get a two channel decoded stream (to the SoundCenter).
And if yon play it back via the SoundCenter, it will pick the core DTS signal and play that.
That is, if ‘a DTSHD file is accepted via USB at all!
That’s what I expect. So the sticker basically says “we support DTSHD but we will convert it to stereo” :)
Yes, because that is what the LG (probably) will do.
The question remains....why put that sticker on the SondCenter, then?
I find it hard to believe anything that Bang and Olufsen says these days!
PBSH
Since yesterday the Sound part of the Settings menu (part of the 1st row in the Settings menu) has been unavailable . Anyone else who have experienced that? When using the remote I still can shift between the different speaker setups, but it is not possible to adjust the Sound settings in the settings menu. I’ve checked for FW updates - no new ones available.  Sw version: 1.3.20036.213941967
I cannot get to sound icon from the first settings menu.  However,  I don't recall ever doing it this way. I just go to the second menu where sound is available.
Mine seems fine, but the tv has to be fully on. So wait until its in place and then try, maybe that’s it.
As to my own earlier question about bluetooth connection to headphones the simple answer is; no... there is no bluetooth transmitter to headphones in the Eclipse... I’m stunned, that’s just plain stupid... But now i’ve got myself an external bluetooth transmitter. I’m yet to try it out, but my dealer says it works perfectly. I’ll post about sound quality and connection stability when i’ve had a chance to try it out.
Can you tell us the brand and model? I use one made from Telme2 but it’s far from perfect.
This is the one. It doesn’t exactly look very “pro” either...
I wanted to test them now But my wife said no, you’ll wake the kid!
So now i have the whole night for testing, since i’ll be sleeping on the couch anyway 😁
