Anyway I will visit my dealer with a DTSHD file and see for myself the result.
Oh - there we go....a file, not a disc ;-)
I am pretty sure, that if you play that back directly via the LG’tv-part, you will get a two channel decoded stream (to the SoundCenter).
And if yon play it back via the SoundCenter, it will pick the core DTS signal and play that.
That is, if ‘a DTSHD file is accepted via USB at all!
That’s what I expect. So the sticker basically says “we support DTSHD but we will convert it to stereo” :)
