Anyone else that has experienced problems with the remote since yesterday? I cant choose sources anymore it just shows "TV" thats all. Tried to do a factory reset on the remote but didn't solve it. Ideas?
BEOVISION ECLIPSE
When you press "LIST" does it show "Beovision Eclipse" at the very top of the remote's screen? I was messing with my remote the other day, and somehow this "product" setting got changed to a different value which then changed the LIST, TV and Music button behavior. You can re-select Beovision Eclipse" under LIST->SETTINGS (somewhere under here, near the "Factory Reset", but I don't have my remote in front of me so I can't tell you exactly where).
Otherwise, perhaps the remote is no longer paired with the TV. I think you can view remote pairings under the SETTINGS application on the BV. Try re-pairing the remote with the TV because the menu items that show up under "TV" are sent from the BV to the remote.
Stan
It’s probably just me who’s either blind or dumb....
But can anyone tell me, how to connect my H9i’s to my Eclipse (wireless)?
i don’t think you can as I was told by the engineers who insmine that the Eclipse does not have a suitable Bluetooth transmitter the only Bluetooth it had is for the remote
So i just bought the top model 10.300€ TV and the top model 510€ headphones from the same company, and i can’t connect these two, without using a cable like it’s 1992.
That’s about right. It was suggested that I buy a Bluetooth transmitter and plug it into the Eclipse!
On another note. We have two pairs of top of the range B&O headphones but cannot use them together on Bluetooth as the iPhone cannot determine which is which and comes up with an error or switches the other pair off!
happy days!
That’s about right. It was suggested that I buy a Bluetooth transmitter and plug it into the Eclipse! On another note. We have two pairs of top of the range B&O headphones but cannot use them together on Bluetooth as the iPhone cannot determine which is which and comes up with an error or switches the other pair off! happy days!
Surely the dealer explained that the headphones you have can’t pair with multiple devices? Or is it the TV that has the one only limitation/ memory? I thought about a BT transmitter for my Avant- but my dealer advised against. They’re generally too unreliable from his experience. Bluetooth has its limitations - it’s been widely adopted recently but really only works well in simple cases in my view. I tried a B&O pair with a BV14, and like others who did similarly, the lack of volume/ power made them useless. It was astonishing.
We have two pairs of Bang & Olufsen Bluetooth headphones, H9’s and H8’s each being connected to a separate iPhone. If both headphones are switched on both iPhones get confused and end up stopping both headphones! Neither of the headphones will connect to the Eclipse! We usually end up connecting the headphones to the iPhone by the 3.5mm lead/jack.
