Hi I’m curious as to how your Apple TV 4K works with the eclipse in DOLBY VISION? Mine works in hdr 60k when connected to the sound centre, but not Dolby vision. B&O have not yet found a solution to playing Apple 4K Dolby vision through the sound centre. It will play Dolby vision thru the other hdmi ports but there’s no control with the BeoRemote One.
Hi. All I know is that when I fire up the Apple TV vie the BeoRemote I get a flash bar in the top right hand corner saying DOLBY VISION with the Dolby symbol. I assume this is generated by the LG TV on receiving the appropriate signal from Apple TV 4K. I have set the Apple TV to deliver 4K UHD signal (it’s not automatically set). I have also made sure the HDMI cable is of good quality. The sound centre is connected to the LG TV via one of the four HDMI ports (ARC).
Where do you get the info about not being able to play Apple 4K Dolby Vision?
Cheers. P
