BEOVISION ECLIPSE
Martin wrote:
Hi Phirstpro,
I read in another thread that one Eclipse-user had problem with the Apple TV 4k. The problem was that he lost the centerchannel when watching movies with 5.1-setup. Do You know anything of this? Have You tried looking at some 4k dolbyvision movies with the Apple Tv? Does all sound-channels work as it should?
Best Regards
Hi Martin  that’s a good question. The answer from me is, I don’t know but I will try it and get back to you soon.  I’m assuming that the centre channel is included in the “Movie” setup and the Apple TV is using the Movie option.  Sometimes it selects “Music” instead.  It’s all a bit confusing really and it takes me a while to get my head around it all!
Hi Phirstpro,
It would be great if You could check it up.
Regards
Martin wrote:
Hi Phirstpro,
Regards
Hi Martin.  I’ve just tried a load of 4k Dolbyvision trailers on the Apple TV.  All sounded spot on with no drop out of the centre speaker.  In fact the centre speaker really comes to its own and provides excellent vocals etc. I’ll now have to watch the movies!
cheers.  Peter.
Great thanks
Hi Martin
Yes I have a Apple TV 4K that is connected. Works fine and use my Beoremote one to control it.
I don't use it as much as I did with my Avant 55 due to the inbuilt Netflix, Youtube and SVT Play app.
I watch 4K movies on my Oppo UDP 203 and only use Apple TV for Viaplay and Cmore+ apps.
//EA
ErikVonAgnar wrote:
Hi Martin
//EA
Where did you find the SVT Play app on the Eclipse? Its not in the LG Content Store?
Hi Erik
Are you satisfied with the motion-handling from the TV when you se fast moving scenes on the screen?
Best Regards
The SVT Play app is in the LG store.
And it works better then the Apple TV app I feel.
I have read that some have had problems with the motion handling but nothing I’ve experienced.
Both picture quality and motion handling are spot on when watching fast moving scenes in movies on Oppo player. On Netflix I haven’t noticed any lag but I watch mostly series and not movies.
Have you had problems?
//EA
ErikVonAgnar wrote:
....due to the inbuilt Netflix, Youtube and SVT Play app.
//EA
You may be aware already, but the ATV 4K Youtube app doesn’t provide 4K resolution, so it’s better to use the built in app.
Are you sure? I`ve just looked at one of the demo 4K HDR videos on YouTube on the ATV4K connected to the 65 Eclipse. It looks as if the picture actually is 4K HDR, and pressing the info button shows 2160p as well. Something I miss, or?
