BEOVISION ECLIPSE
Have some major issues with the network card in the Beovision Eclipse. Wired I get 2 mbit and with wifi I get 100 mbit that works for a couple of hours and then it goes down to 2 mbit. Going to settings and disconnecting and connecting again resolve the issue.
All my other devices get 100 mbit on the same network. Ive tried booth 2.4 and 5 ghz but booth have the same issue with the Eclipse. Any ideas?
tigerisak wrote:
Have some major issues with the network card in the Beovision Eclipse. Wired I get 2 mbit and with wifi I get 100 mbit that works for a couple of hours and then it goes down to 2 mbit. Going to settings and disconnecting and connecting again resolve the issue. All my other devices get 100 mbit on the same network. Ive tried booth 2.4 and 5 ghz but booth have the same issue with the Eclipse. Any ideas?
Maybe this has something to do with your eco or energy mode settings?
In General/Eco Mode Ive set auto power to off
In Picture/ Energy Saving Ive set it to off
Also turned off Quick Start+
Still the same issue Im afraid
First time i don't have a Beovision in 25 years....i am actually a bit sad.
But not enough value and differentiation in eclipse, and appalling and expensive service here in Switzerland....i just bought the Loewe Bild 5 65 OLED, good bye Bang and Olufsen.
Hi Beofan67,
Can You really confirm that Flac-files will work when playing music thru Eclipse from a NAS?
I have some days ago got confirmed that this issue is still not solved and is under B&O:s list of things that will be fixed in the future. Thats why I am very suprised that you got it to work.
Best Regards
I have to say the same. First time a non Beovision in 24 years. It was a hard step.
I'd have bought the Horizon 48 (a larger size doesn't fit), if there was the controlling option of the motorized stands. Now i've got an Samsung qled 49 - brilliant picture, easy app integration, sound is... let's say ok, and i've saved 3500€. Actually i see no alternative in the B&O range.
Martin wrote:
Hi Beofan67,
Best Regards Martin
Beovision 7-55 3D with Bluray (sw 13.12), Beolab 5 (sw 3.30a), Beolab 3, Beolab 3500, Beo4, Beosound 5, Beomaster 5, Beosound 9000 Mark III (sw 3.4), Beolink Gateway (Beolink App), Auralic Aries (Femto clocks)
I think there are two ways to do this:
1) play over the LG DLNA app in the TV
2) play over the soundcentre using the Beoapp.
As I understand it’s 1) above that does not support Flac. Correct?
Hiort wrote:
Martin wrote:
Hi Beofan67,
Best Regards Martin
1) supported FLAC from USB, from NAS unsupported (for the moment). WAV is NAS supported, so if server transcode to WAV it works
2) Correct 2ch FLAC is supported
Hi Martin,
I have just tested it again (just to be sure I am not becoming mad 😁) and can CONFIRM that I can play FLAC files on my ECLIPSE both ways:
1) LG Webos Music app > select my NAS > go to map and play FLAC files (see my prntscrn I posted earlier in this thread)
2) Via the B&O app > music > music map > select my FLAC file.
The only bug still is that when I use the 2) B&O app  I will get a totally green screen (which I can turn off via my beoremote)
Btw I have a NAS Synology DS213+.
Ruud
As the eclipse screen is a C7 , now that the C8 has been "launched", i read in engadget that the C8 is the Best of CES 2018
How long till the screen is updated in the Eclipse i wonder?
It normally takes a while for them to reach market anyway , like 6 months from CES.
https://www.engadget.com/2018/01/11/best-of-ces-2018-winners/
Best TV Product:
