BEOVISION ECLIPSE
Serious question - has anyone asked their dealer about any assurance of TV serviceability/repair period? It would be pretty galling (to me at least) to have to throw out a £7.5K B&O Soundbar because the £1.5K TV was obsolete/unrepairable!
I did.  The answer was 1) B&O is required by law to stock repair parts for 7 years and 2) future LG TVs will fit into the SoundBar.  I'm a little skeptical about 2) since having LG commit to maintaining a specific form factor for a number of years sounds rather optimistic.
In some ways, this challenge exists even without taking repair into consideration.  That is, LG releases new TV models every year - will B&O have to update the SoundBar every year to fit a new TV?  Will LG continue making the 2017 TVs so B&O doesn't have to update the SoundBar?  Will LG maintain at least one model that fits the SoundBar?
This isn't their first rodeo so I would hope that these details have been well worked out as part of the partnership.  The only question is how long does the partnership last...
Sounds reasonable, although I thought it had been said that your no.2 wasn't in their plans.
Just asked the same thing and got more or less the same answer. With in the first 3 years, it’s all on B&O(repair or replace). After that they have to make you an offer with in 8-10ish years or less. But that goes for the avant and 7 and 11 and 12 too, as in is standard practice.
That’s what i was told just now
Razlaw wrote:
Problems, just as beauty, are in the eye of the beholder.
Ha !
So what do you think you will do ?
Stay with status quo ?
Or upgrade ?
Hello I am the owner of 55 eclipse from yesterday,my English is not fluent I am from france
good  image is good as on Panasonic ez 950
i have some questions
1 I have tried to put a media player on hdmi 1 ( not hdmi A) which is on the side of screen , I get image but no sound have you some tip
2 if I listen music from Apple TV from hdmi À for instance how I can shut of the screen ?
i began to discover the eclipse so I have many questions
thanks  for you help
i am glad with this new beovision
thanks  for you help
thanks for you help
1, you can’t get any sound from the HDMI ports from the Tv. You must connect all players to the Sound Centre. (Hdmi A, B, C...).
2, if just want to play music and do not want the image to be turned on you press LIST on your remote.
Then go down to SHOW IMAGE or what the French word is. press it and choose IMAGE OF. 🙂
Hope you get it working and understand my English.
//EA
Thanks Erik
i have understand
do you think if I connect mediaplayer on hdmiA  if I connect the optical line of media player  to the line in on the backside of sound center can I have sound ?
I have more  theee sources  on hdmi A ..with puc but when I press tv on remote and choose appletv for instance all the three sources light on ,is it possible that the only source on is what î have press?
2 if you have more than three sources for instance five , can you put three on a switch hdmi 4k and connect to hdmiA, I understand that puc can t work , ? ( have to do it with they remote control )
if the switch 4k  with hdr and 60fz is a Good idea do you know Some  brand ?
3 have youmade some « calibration «  I would try to modify some data
the image is not bad « out of the box »
thanks  a lot
No sure if it was mentioned already, but how does the speaker bar on the Eclipse compare to the one on the BV11/14?
