My dealer didn't even tell me about functionality issues and the fact that the NL/ML had been discontinued.
I think they were embarrassed. Only after pestering my dealer and emails to Denmark was I told.
Denmark didn't even reply to my question of NL/ML Functionality.
An AV cable was fitted and I was told to control the Beosound 4 manually as it would be too complicated to use beo4 and BeoRemote one. They struggled with the BeoRemote one. The Beosound 4 now plays via the Eclipse . With the Eclipse on, Use the BeoRemote One to select Music. Then scroll down to Line in. Turn on Beosound unit and CD/Radio will play. Then manually change Radio stations or CD. If you want to do this fine. Premium brands with their premium products should integrate. I am disappointed. If people own these products deep down they will be too.
My eclipse 55 is very good. Unfortunately I wasn't told of any issues until I started reporting them.
It is not worth £8800.
Will be returning my Eclipse and buying AV separates and a 2018 LG Panel next year.
