Fully agree.
The sound from the Eclipse is better then the Avant 55", so it should be priced a bit more.
The picture is far better on the Eclipse then the Avant 55", so it should be priced more.
The WebOS on the LG screen is far better and smother to operate so it should also be worth something.If I go and buy a new TV from Beo that I want to stick with me for some time. I will not go for an old Avant NG with a buggy Andriod system with a screen and sound that is worth then the new one? The Eclipse is worth not having a electric cinematic curtain or have glass in front the tv.
It is still cheaper then other Beovisions from the past.
Damn the Eclipse gets a lot of hate!
1, It's the best Beovision on the market.
2, No one is forcing you to buy an Eclipse. If you want and old Avant for the looks and geeky tech stuff, go with that one.
If you like an elegant piece in your living room buy BV14 (and buy it fast). Or, if you want the best sound and picture quality of them all, go for Eclipse.//EA
