So the magic is in the stand... Pitty!
55
7145 with with fabric speaker cover
Aluminium cover extra 800!
Motorised stand 1399
Looks like a light version of bv7
That's actually not that bad. 1000 cheaper would of been better, I think the Avant 55 was 5000 when it launched. The two major things I am curious about is will it come with hdmi 2.1 and will you be able to upgrade the panel. Someone mentioned the later in one of the threads and if its true it could change the longterm value proposition somewhat depending on the cost of the upgrade.
I don't believe the current 2017 LG's come with 2.1, so i doubt that the Eclipse will.
From what i read, full 2.1 capability requires a hardware upgrade. Certain aspects (dynamic metadata for HDR) may work over 2.0 with a software upgrade.
Personally i wouldn't worry, but thats just me.
Most of these new capabilities require physical discs to show the TV's ability at its best. I'm not inclined to upgrade my (30-40) Blu-Rays to 4K UHD versions, and then again to HFR versions anytime soon. Picture quality is pretty damn good on Blu-Ray, and yes while 4K HDR versions will be better, in the end most modern films (which is what will be available in newer formats) aren't very good. Upgrading a disc collection is also expensive - my Blu-Ray discs cost 10 pounds max, fine for a classic movie, but 4K UHD discs are roughly 25 pounds....
So i wouldn't worry about it
Good points, I agree I dont think not having it is a deal breaker.
This is 95% correcthttp://www.recordere.dk/2017/08/beovision-eclipse-oled-tv-ventes-klar-paa-ifa/ An article in Danish with a mock up.
