9 LEE wrote:
Bv7Mk3 wrote:
What i understand that the speaker of the eclipse will attach/clip under the bottom of the tv and yes a sort of bv7 finnish/look.
So, more of an "e-clips" than eclipse?
I don't think you can remove it since I understand the bar hosts the connections panel.. The soundbar is not under the TV, it is part of the TV. You have the screen (thin like all the new LG panels), the soundbar and then some more glass under the soundbar. the whole thing is like a glass square with a soundbar in the second half, and the soundbar sticks out horizontally on both sides (obviously not just to the left or the right :) ).
My english is too bad too describe it properly sorry.
The bar is supposed to be very powerful and great-sounding ("unlike anything I have heard of" the friend said).
There is only a motorised stand like the Avant (but smaller foot print thank god) or a wall mount.
I'm a BV10 and 11 owner. They fit perfectly with the way our living room is designed. I like the design of the new TV but no easel stand (that covers the amount of stuff which is behind the TV - not everything fits on STB brackets) means that the only option for me would be to wire the house and install an HDMI matrix to have all the equipment in a different room.
I think I read somewhere that B&O will present the TV at IFA later this month, so dealers should receive the first pieces shortly afterwards.
