flatwhite wrote:
Hi Christian,
I have the following setup:
Ethernet cable to SoundCenter
Ethernet cable from SoundCenter to LG
LG is no configured for Wifi and gets it's internet from the cable to the SoundCenter.
LG Configuration shows "Not connected"
Maybe the TV is confused which network to use to talk to the soundcenter. Try to remove the wifi connection from it and see what happens. Also try a different cable between the LG and the SoundCenter.
Hi flatwhite
Thx for your clarifications. I have now a new C9 standing at my home which i attached to the Soundcenter. Compared to my tries to make the CX work, i had more success with the C9, where the sound level is now working and also chosing the source. Is it correct, that changing the source means to switch the configuration off with the BR1 and restart it by choosing the right source on the BR1?
Also with the C9 combination, the wired ethernet connection is displayed 'not connected' as soon as i start the B&O app on the TV. Before starting, it displays 'Connected to the internet'. Quite weird.
Which LG and Soundcenter SW (3.60.xx or the newest 5.10.xx) version are you running on your configuration?
In addition, the PQ of the C9 is horrible compared to the CX and also to my former E7. The picture is very often dimmed very dark. Do you also see such effects and could you correct them?
Regards
Christian
