BEOVISION ECLIPSE V2 Coming April 2020
Very much looking forward to it! Also if B&O changes the way the panel is integrated from a software point of view. So more the Harmony way and use the app inside webOS of the LG to control the B&O world.
I like the Harmony very much, which is great to hide the enormes size of 77" screen in a typical European living room, but with 65" this is not so critical. At least for me.
I would guess that it will be as the Harmony,
So not as good as the current Eclipse, but much more flexible.
I would also be sure that the current sizes 55" 65" will be in the V2,
If 77" comes I will be surprised
A 48" would be great 😁
An Idea, If B&O makes a flat plate to put on to of the sound center, you could wall mount all C9/X model above it.
Then you have the Soundcenter/Beosystem 5
I´m glad to hear it. But there are some questions...
- in what size will it come
- will it have atmos
- can you change the panel in some years for a new one as expected
I´m an owner of a BV 7 MK II (2013) and till today I´m very satisfied with the picture and that I can still use my old Beosystem 7000 with it.
- in what size will it come?: Properly in 55" and 65"
- will it have atmos?: Most likely not
- can you change the panel in some years for a new one as expected?: Yes you can, if LG do not change a lot in design on their C line.
Very curious to know the sizes... Hope that the 55" will still be available.
Karel.
Great !
I suppose the look will be the same. and I guess same sizes available.
Apparently, it will be LG  C9, as far as I heard...
I am just waiting for the official announcement to place an order.
Thanks for the news, Emil !
Great !
I'm pretty confident they won't ditch the 55". I have a BV12-65 and it requires a lot of wall real-estate and most people say it looks too big (but love the TV and picture). I'd probably move down to a 55" for my next TV.
Is it working once again? Hope so.
The eclipse 65” looks a lot smaller though as the bv12 has enormour bezzels, pretty ones but big’uns😎
JFJBrussels wrote:
Great !
If the look will be the same.......from behind, it would mean, that it is costum build.
Which again would mean, that you’d have to buy it as is.....with no option to swap for a later C version (or buy the C9 elsewhere or already have one).
In my understanding it will come with a stock C9....but I really have no knowledge, yet.
On the other hand - you don’t very often look at it from behind.
Will be interesting how they make the solution when connecting both parts!
Usually when you wallmount the C’s, you use a bracket on the tv.........which you don’t do with the Eclipse.
