BeoVision Eclipse software update
New software for Eclipse
2.7.37196
And the problem with “Clip Protection” is finally solved. Hopefully other problems from the previous software update are solved too.
Unfortunately Bang & Olufsen’s support line is very hard headed to communicate with, it’s simply impossible to have a constructive conversation, especially if you have knowledge yourself at technician level. They will never, never admit there possibly has been flaws in one of there software updates, the dialog will turn to pure nonsense if you confront them.
With the software update yesterday there is still problem with Stand-by indicator when playing music (Deezer, DLNA). With the software 2.5.xxx and earlier, the standbyindicator always had a green light when playing a Music-source. From software 2.7.xxxx the standby-indicator sometimes lights up when starting a Music-source but after 10 minutes it go off (black). I have send this software bug to B&O-support but nothing happens.
It is not a big deal but I agree that it is impossible to make a decent conversion with B&O and their support-team.
Best Regards
Martin Ström
SWEDEN
spezializten wrote:
When I wrote 99% I meant the fully B&O functionalities! =)
BeoRemote is working with all Sources, Speakers, Sounds, Light, Picture, LG Sources, LG HDMI. (Right now only Favorite Buttons and Home Control Webpage isn't working). But I think that might be a bug for Beo with ex Harmony as well?!
BeoRemote can also control the LG functions, like mouse cursor, movement etc. The Beo App (iOS) is working perfect and also the connection with BLGW and all controls.
I think that Sound Center is using the Remote Control API for LG in some way to control everything.
So you can’t control the stand?
Does anyone know if this is a staggered release? My Eclipse 55 is still on 2.5.31533 even though it has automatic updates enabled, however this is the s/w version being displayed via both the TV and B&O app...any ideas/suggestions appreciated.
MJ
MJ
Same on my side but I am located in Canada. Perhaps the update is released region by region. With all the various problems reported here with the new version, I have disabled the automatic updates until a stable version is released. It will also be a good thing to check the changelog of the new version to see if new features have been added or a list of the bugs fixed.
Regards,
Jean
Still on 2.5 here also, situated in Holland
Still on 2.5 in Canada.
Also in the last 10-14 days I have noticed that if I Initially use the B&O app for turning on the eclipse and playing music using deezer there is no sound from the eclipse. You can see the volume bar on the right go up and down but there is no sound output.
If I start the eclispe using the beo remote and select TV on hdmi2 and then use the B&O app sound is then output from the eclipse.
I had the problems the other users mention with no sound output back in the beginning of Feb,
Lastly has anyone experienced problems using 4k UHD sources and getting them to display on their eclipse?
I have a 65” eclipse.
Thanks.
I have one of the very first Eclipse 65", and had some issues playing 4K HDR via HDMI through the SouncCenter early on. They changed a small ciercut board, but that didn't help. But it turned out the HDMI cables I used were too bad a quality, after changing them it has worked fine.
/MikaelB
Thanks.
I own a 55" Eclipse since about 1 year now and I have no problems splaying 4K UHD videos from either the built-in media player or Youtube. HDR, HLG HDR and Dolby Vision videos all play without any problems (Youtube videos can be only HDR or HLG HDR ). For audio, a Dolby Atmos soundtrack plays properly if it is wrapped in a Dolby Digital plus container. A computer outputting 4K resolution connected via HDMI works also.
When playing something using Wifi, don't forget to put the "listening mode" to off in the menus as it eats bandwidth.
Regards,
Jean
