The Soundcenter even has it's own list price (3.168 euro in Germany)... Seems like as a fair price.
Maybe the Eclipse 2nd Gen will be flexible enough to be used both as full BeoVision and as separate Soundbar?
Actually the missing 1% is as far as I know are bugs that exists for Beovision Harmony which is more or less an Eclipse with LG C9.
Might be - but there is always a chance that they will resolve that for the Harmony.
However, will this also happen for a diy-Eclipse-C9/the SoundCenter?
@spezializten
How does it look from behind?
How (well) do the two parts fit together?
Not a big problem, when people want it wallhanged, but many want theit tv on the stand....preferedly to turn it also.
When I bought my Eclipse ~2 years ago, there was a separate line item (each with a price) for the screen and soundcenter. Therefore I would not
read too much into this.
Stan
I have used two separate mounting kits:
The Sound Center is mounted with the ordinary SCREEN brackets (which is meant to be used for the 55" LG monitor) but I have made a special solution for wall mounting. Will add some photos of this later. Didn't dare to mount the entire Sound Center in these brackets and screw them into the LG Monitor (Because of the weight). LG TV (40kg) + Sound Center(35kg)
The LG Monitor is mounted with the bracket in the picture. I need to have access to allt the cable connections inside the electric box the wall. 16 x Cat7, Power outlets etc.
Spezializten, did you manage to install the Bang & Olufsen app on the LG to get full control of everything with the Beoremote, or it's just a Harmony-compatible software and you just stick with the LG remote ?
When I wrote 99% I meant the fully B&O functionalities! =)
BeoRemote is working with all Sources, Speakers, Sounds, Light, Picture, LG Sources, LG HDMI. (Right now only Favorite Buttons and Home Control Webpage isn't working). But I think that might be a bug for Beo with ex Harmony as well?!
BeoRemote can also control the LG functions, like mouse cursor, movement etc. The Beo App (iOS) is working perfect and also the connection with BLGW and all controls.
I think that Sound Center is using the Remote Control API for LG in some way to control everything.
Could you use the motorized stand with this setup?
