BeoVision Eclipse software update
Have you tried to factory reset your soundcenter?
I got the problem too with no sound after the latest update, ending up making a factory reset of the sound center.
Afterwards I find out that the problem was related to “Clip Protection” a function which is turned ON by default, but in my case turned OFF because I have recognized it cut off the lower bass to my BL5 speakers.
But after this software update it is no longer possible to disable the function, if doing so it will replace the sound with a high frequency tone, which will not disappear before turning the function back ON again and restart the TV.
I lately also has experienced, several times the remote has lost the communication to the TV and need to be re paired, sometimes it’s necessary to make a factory reset to the Beoremote before it is possible to successfully pair the two.
I already has contacted my B&O dealer and even B&O too, so just hope they very soon will come up with a solution.
Sorry my post was double published and now I can't delete it
Hi, I have also a problem with my Eclipse after latest software update (2.7.xxx). The standby-indicator that always lights green when playing a music-source (Deezer or Music DLNA) dont light up at all anymore when playing music source and the screen is black. In the Manual for the Eclipse it says that the standby-indicator always should be green when the screen is off and when a music-source is played.
This software error is not a big thing, but they have done a lot of things with the soundcenter with the new software and I can NOT see any improvements at all. Just negative things with the new software. I hope B&O reads all this comments and make a fix.
The bad thing about B&O and software is that it always take so long time to fix an error in the software compared to other brands. I wonder if B&O ever will be good at software in their products. It is now many years with bad software in different products (Beovision 14, Beolab 50, Beosound Moment etc....).
Best Regards
Martin Ström
SWEDEN
Yes it seems like they have done a lot with the sound center and for what reason and just agreeing, hope really B&O read everything in this tread.
Another thing I experienced after this software update is that a bad sounding noise can appear in the speakers when turning the system off.
Yesterday I was visiting a friend who has a LG C7 65 inch.
Out of curiosity I asked him for the current sw version of his tv - 05.80.35:
On my own Eclipse 55 inch I have version 03.60.45:
It looks like the Eclipse sw is back level compared to LG C7.
I have seen updates to the sound center sw, but not to the screen part of the Eclipse.
Does anybody know if the sw for screen part of the Eclipse is frozen or still being updated by LG or B&O ?
Best regards
Dyssegaard
Yes it’s a special version of the OS. But we are missing out on a lot of goodies with the latest versions I’m afraid.
It is a shame that B&O is not upgrading the LG OS! Why? If it is due to B&O related interface I wonder how future proof the Harmony will be
I think the LG update is independent of harmony just like LG and soundstage
That is the beauty of the Harmony, the software of the WebOS platform is fully controlled and managed by LG, interface to B&O is handled with an app on WebOS. So no worries here any more. Only downside is that LG is not known for keeping older TV's up to date.
