BeoVision Eclipse software update
My Eclpise works fine. But as every ”computerbased” electronics needs to be reboot sometimes!Hi, just wondering if the Eclipse is having any software problems or is it completely stable? I’m considering an Eclipse but after the Android experience with my Horizon I’m a bit reluctant. Thanks for any guidance.
Hav had my Eclipse since they first came out, and it had to be rebooted once in a while the first 6-12 months I had it. Now I can't remember when I rebooted it the last time.
So no instabilities in my experience. Enjoy it every day.
Hi, I agree. No sw issues. It is 99,99% perfect. It is even better with the sw than my old reliable BV 7-55 mk2.
I strongly recommend the Tv.
best regards
I received my Eclipse last week and I found a very interesting feature that, to my knowledge, was never mentioned in the forum.
If you use the Bang & Olufsen application to control the Eclipse, the third screen implements the "magic remote" feature (cursor and scrolling). When the Eclipse was released, a number of people complained about the lack of this feature that is provided in LG TVs with their "magic remote".
The light gray portion at the left is a trackpad that works exactly like the one of a laptop. When you touch it, a cursor appears on the TV screen and you can select items with a small tap on the phone screen. The narrow dark band at right can be used for scrolling in menus, etc.
Enjoy,
Jean
Oooh, I didn't know that.
I do like Lightroom - will try the ATV app!
