BeoVision Eclipse software update
Thanks for the pro-tip 😁
BEOVOX141 wrote:
Just find that service menu,- it might require a few sound files and a bit of soldering
Happy hunting
We are recently experiencing 2 issues with our 65 Eclipse:
1) After using the Eclipse as speakers- streaming Spotify music to the Eclipse - for a while, then turn the Eclipse off, when we then after a while turn the Eclipse on again using the remote “TV” + “TV”, there is no picture from the STB, only the sound. The picture does not come on using the “List” + “Picture On” either, it seems that nothing else works to get the picture on. If we then turn OFF the Eclipse, wait a bit, and then turn it on again, then both picture and sound are present. The STB is set as “Always on” (have tried different PUC options).
2) We have problems with the built in Netflix and Amazon app: Streaming stops each couple of minutes, and it take some time (15-60 seconds) to load new content. The Eclipse is wired with a CAT6 cable directly to the router. We have upgraded the internet subscription to 260 Mbps. A parallel CAT6 cable goes from the router to the ATV4k box that is connected to the Eclipse through a 18Gbps HDMI cable as well, and streaming to the ATV4k works perfectly (so now we must watch Netflix and Amazon Prime through the ATV4k box). When testing the network speed using the Ookla Speedtest app on the ATV4k box, it shows a steady 259-262 Mbps download speed. When running the Internet speedtest app on the Eclipse (LG), it is veeeery slow to start up, fails more often than it works, but when it works it shows 10-30Mbps download speed. When the Eclipse was new, we got 60-70 Mbps using this LG speedtest app.
We've tried unplugging the power to the Eclipse several times – with no effect. This must be an issue with the latest SW upgrade on the Eclipse/LG set. Anyone else having the same issues?
New software update today
And still none of the software updates that has been in the C7 for several months now....
I guess they still have to make it through B&O's rigorous software quality review and testing cycle.
Or B&O didn't negotiate well with LG about who got and who paid for what.
Hi, can you update this list with the new
software 2.0.xxxxx. I would like to know all fiixes done in this software update.
Best regards
Any news on Technicolor, My buttons or different stand positions from standby?
I heard MyButtons and passthrough of LIGHT and CONTROL commands to the BLGW are coming in another decent update in July.
I got this in a mail from my dealer:
SW update 2.0.22617 update content
1. New features (OMO information from Hotnews):
2. One touch from standby – on BeoRemote One.
3. Ability to use TV and MUSIC buttons on BeoRemote One to switch on your TV from standby.
4. Customise source lists – on BeoRemote One.
5. Ability to select which sources are shown in the BeoRemote One source lists.
6. TuneIn buffer. Ability to setup the network buffer for the TuneIn netradio source to avoid sound drop-outs.
The software release will also include Atlona matrix support. This means support of the Atlona matrix is now part of the common software, hence you do not need to request a service software for getting the Atlona support feature.
I have also updated it in the original post.
/MikaelB
New software out tonight!
