I am very satisfied with the stability in software now for the Eclipse.
Does anyone know what´s in pipe-line in the future for the Eclipse regarding "new functions" or other improvements?
Best Regards
Best Regards
I have updated the original post with the latest info from my dealer.
I am still waiting for a solution to the 4K pass through problem, when plugged in directly to the soundcenter.
What problem do you have?
I have a PS4 Pro, and a Apple TV4K with Dolby Vision running without any issue.
My problem is my XBOX One S only delivers 1080 Full HD (not 2160 4K), this is a known problem when you use the HDMI's in the SoundCenter. If I switched to the HDMI in the panel, it would work. But then I cannot use the PUC.
Best Regards
I know of 2 major updates they are working on.
I have only ONE problem were I think it is software-related. I have one Apple TV connected to HDMI C and one Oppo bluray connected to HDMI D. I use PUC-codes for both of these devices.
My problem: When I start Apple TV:n then the Oppo-player starts also. When I start Oppo-bluray player the Apple TV starts. When I start ordinary TV both Apple Tv and Oppo bluray starts up.
Is there a solution for this?
Best Regards Martin
Future updates:
Get the "My Buttons" to work.
Differens standing positions for music etc.
60 Hz on Apple TV 4K
I had a few occasions where the center channel sound did not work. Front and rear speakers did give sound, but no center channel sound. Problem once occured using the internal netflix app. Restarting the app/movie solved the problem.
Other people had this same issue? Is there a fix?
After recent software upgrade I have a serious problem when listening to Deezer or using my connected NAS with the B&O-app.
Some times I get no 2.0-channel sound at all. When I go into the "sound-info"-menu I says 0.0 (sound input) when i should say 2.0.
So the inbuilt streaming function in the soundcenter dont send out any sound. When this happens I must put the power off and I have also made a "factory-reset" of the sound center. But it happens again. Some times it works several days but suddenly the sound stops coming and the "sound-info"-menu in the TV says 0.0 (=no sound input to the soundcenter at all!),.
Have anyone had this problem when listening to music with deezer or a NAS with the B&O-app?
I am afraid that there is some issue with the soundcenter. My dealer had not heard any problem like this before.
Best Regards
They HAVE to enable bluetooth for headphones directly from the LG panel, since they haven’t bothered putting a bluetooth transmitter in the soundcenter
Just find that service menu,- it might require a few sound files and a bit of soldering 🙂
Happy hunting 💡
