BeoVision Eclipse software update
Thanks - yes, the Eclipse is different!
However, as long as I use the Join command, I can listen into what is playing.
If you e.g. have a ML-based audiosystem in the same room (set to Option 0),
you can start that manually, push Join on the remote...and listen on the Eclipse, right?
Not the best way, but still there is no need to get rid of an existing ML system, if you don’t want to.
How about the other way ‘round?
Can you map the sources from the SoundCenter (and maybe those from the tv/connected devices) in the Converter, in order to use these in the ML setup?
If yes, this would give some value to the old system.
Anyone any news on BLGW software update for the Eclipse?
I have A question about the eclipse. When I go grom tv to tuneln ( via button musik) I got the music but the eclipse becomes to A green field. Now I must alwAys to the button “No picture”. Is this normal?
I get same and need to manually switch off the picture from the remote.
Ok quick update. I used to get a green screen when playing Sonos connect through the optical connection until my installers, heroically back for day two to work through some issues on first install , performed a factory reset. That glitch no longer occurs and when playing Sonos as a music source the screen is always black - unless displaying volume change info.
Any news on when "my buttons" will work?
I have updated the original post with the latest info from my dealer.
I am still waiting for a solution to the 4K pass through problem, when plugged in directly to the soundcenter.
Seems like the green screen problem have been solved by sw 1.4, have a look at the original post.
Mikael, I can not find this in the Menu:
”5. Improved CEC disabling feature called "HDMI Control on/off " (16574)”
What problem do you have?
I have a PS4 Pro, and a Apple TV4K with Dolby Vision running without any issue.
