BeoVision Eclipse software update
Hi, I have a BeoVision Eclipse 65 and really enjoy it, and I want to play with the technical possibilities that it offers. And therefore I would like to keep up with what is offered in new software updates. Here is what I got from my dealer.
As I understand it from my dealer the LG updates are pushed to the LG panel when the SoundCenter are updated.
Version 1.0.14310. Release date 27-08-2017
Symptom:
General improvements
Version 1.0.15226. Release date 18-09-2017
Symptom:
1. Expand/join via Bang & Olufsen app does not work in some cases (VCC-3786)
2. Cannot switch on with source selection, "HOME" is the only button that can switch on the TV (KE16572/16698).
3. Limitation to only have one BeoRemote One BT paired per TV (KE16572).
4. After completing first-time setup, the PUC did not work (KE16576)
5. No sound at start-up the first time after the software update or first-time setup (KE16573)
6. Sound output sometimes gets messed up e.g. centre sound playing in wrong speaker (KE16762).
7. When you start Chromecast audio from standby, there is no sound, and you have to restart the cast (KE16570)
8. YouTube sound has high distortion in link room(s) (KE16577)
Version 3.60.20. Release date 21-09-2017
Symptom:
- HbbTV crashes and becomes unresponsive (KE 16575)
- General improvements in the interface between the SoundCentre and the TV
Version 1.1.115613. Release date 04-10-2017
Symptom:
1. KE: YouTube sound has high distortion in link room(s) - further improved (15577)
2. KE: Suddenly becomes unresponsive when playing Deezer and TuneIn - mains off/on is then needed to get it up and running again (16855)
3. BeoVision Eclipse SoundCentre - Loud noise, sounds like a machine gun (16843)
4. KE: BeoVision Eclipse SoundCentre - Does not start, after mains reset the Eclipse works again, but forgets speaker groups (16868)
5. SCB did not reset to default after being activated in the TV menu (VCC-3776)
Version 1.1.16344. Release date 11-10-2017
Symptom:
Intermittently no sound, standby brings the sound back
Version 1.1.17013. Release date 31-10-2017
Symptom:
1. The previous software version 1.2.16504 did render some Sound Centers unresponsive after updating (KE16926).
2. Adaptations to a new Google Cast update to prevent Google Cast from not working.
3. New WPL firmware (improved 5 GHz performance if speakers are also updated. At the moment the WPL receiver software is only used in BeoLab 50 and BeoLab 90).
Version 1.2.17267. Release date 08-11-2017
Symptom:
BeoRemote One lists 'TV' and 'MUSIC' are empty, and the tv will only switch on by pressing HOME button
Version 1.2.17534. Release date 21-11-2017
Symptom:
1. "Stand" option is missing in remote and in the TV (17026)
2. When playing sound above vol. 30 and BL50 is connected via WPL, the HDMI-2 loses connection - ARC lost indicated on screen (16848)
3. Network Link leader election is running in a loop causing several stability issues e.g. the operation with BeoRemote One is not performing OK - Menu operation etc. not possible. Mains off/on needed (16834)
4. In rare cases the OLED TV will not switch on (VCC-4535)
5. After switching TV on and using it shortly, it becomes unresponsive, only registering a single press every 30 seconds (VCC-4283)
Version 1.2.18278. Release date 02-01-2018
Symptom:
TV not able to switch on. (These software updates will prevent this error)
Version 1.3.18795. Release date 15-01-2018
Symptom:
TV does not switch on, mains reset is required (KE16870)
Version 3.60.30. Release date 30-01-2018
Symptom:
1. HDR function does not work on YouTube
2. Lip sync issue when streaming
3. Netflix: voice is played back as a machine sound
4. TV cannot play FLAC files from NAS via DLNA
5. After a reset to default, pairing screen shown before SoundCenter is ready to pair
Version 1.3.20036. Release date 21-02-2018
Symptom:
No sound from audio/video source when using EXPAND or JOIN (KE17320)
Version 1.4.20794. Release date 14-03-2018
Symptom:
1. Wireless Power Link speakers do not switch on, but are still connected (16985)
2. After some time operation becomes very slow, then the TV stops responding, and the volume display is no longer shown. After standby it works again for some time (17172)
3. The floor stand turns a bit each time the TV is switched off and on. Standby and on position remain the same (17127)
4. Green screen when selecting TuneIn (16835)
5. Improved CEC disabling feature called "HDMI Control on/off " (16574)
6. TuneIn from SoundCentre sometimes loses the credentials and starts playing a Dutch radio station (ASE-3551)
7. Further stability improvements in the JOIN functionality (VCC-4642)
8. A paired Bluetooth device can make the TV switch on "by itself" when discovered by the TV. It should only switch on the TV when music is playing (VCC-4905)
9. TuneIn buffer time setting was not accessible via the menu (VCC-4902)
SW update 2.0.22617 update content
1. New features (OMO information from Hotnews):
2. One touch from standby – on BeoRemote One.
3. Ability to use TV and MUSIC buttons on BeoRemote One to switch on your TV from standby.
4. Customise source lists – on BeoRemote One.
5. Ability to select which sources are shown in the BeoRemote One source lists.
6. TuneIn buffer. Ability to setup the network buffer for the TuneIn netradio source to avoid sound drop-outs.
The software release will also include Atlona matrix support. This means support of the Atlona matrix is now part of the common software, hence you do not need to request a service software for getting the Atlona support feature.
Feel free to post if you get info on new updates.
I think this thread is a great idea to help keep track of software bug fixes for the BV Eclipse.
During the few weeks I've had Beovision Eclipse, I have several times experienced losing control of the TV with the remote control, some features work but I cannot turn off the TV and have to switch off at the power outlet.
Someone who has experienced similar.
I have had no problems with my remote, since I got mine a month ago.
Do you have the latest software?
I also have issues with the remote and turning the TV off.
Since Millemissen didn’t reply, I must react : this is not a bug, it’s a feature!!
why on hearth would you want to turn off your Beovision, it HAS to be on all the time!! ;-)
I have no personal/at home experience with the BV Eclipse.
Some day - m’bee - who knows.
And yes, I have the latest software. At least it seems I’m not the only who have experience issues with turning off the TV.
New firmware was released yesterday by LG. Version 04.70.10.
I saw my eclipse installed an update today. Does anybody know what it covers
