BeoVision Eclipse Issue Bluetooth
Hi everyone, when I use bluetooth connect to Eclipse TV to play music, it shows only this giant Green Screen, super light. Any idea how to change it?
LG is using the new greentooth technology ;-)
Nice setup! 🙂
This is a the case also when activating spotify/tunein via the App.
Only solution is to close the screen from the remote. I do not have an eclipse but there should be a Picture Mute command under "LIST",
Quite sure this will be fixed in an coming update.
Thx man! Is this also the case with your eclipse? I have a friend in HONGKONG and his Eclipse shows black screen when play thro Bluetooth lol, the country different version different even from these things? Cannt believe it...
I don’t have eclipse but Avant and I’d be interested to know when you connect via Bluetooth does the TV and the SoundCentre show up as separate devices ? I was thinking do you connect to one and not the other ?
How are you connecting ? Do you connect via the app ?
If you connect via the app is it shown like my Avant is ?
I’d try this app rather than say native Bluetooth connection direct from device to eclipse
It’s connectioned directly with native Bluetooth, but thanks for the tip! I’ll try with the B&O app...
P. S. I like your simple naming of all the devices ;)
No need to use bluetooth on the tv, when you have a SoundCenter, that supports bluetooth.
You can, but why should you, when you have an Eclipse.
SoundCenter, aka soundbar. 😎
I have been a B&O and BeoWorld follower from many years but just now I am joining. That is a beautiful home so I am sad for the owner that B&O is distracting from it instead of making it even better. That is only my opinion because the 4 controllers and a screen like that is not fair to a nice customer. And if I am wrong I am sorry.
