Hello I'm looking for help with my Stand. The stand is not detecting nor showing.
Under menu Service System Voltages, it shows as 12V == 0.03V
Can someone please let me know what that means?
When the stand worked, it was quite jerky and not very smooth.
Also, periodically, the green light will flash rapidly while turned off. All connections are fine. I've tried unplugging for hours, but it has not helped.
Thank you.
