More seriously though, can I take the 'spare' Stage I have here and use it with this frame and an a panel?
Yes you can!😁
No you can't. Are you just assuming or have some knowledge? My dealer says this isn't possible.
Yes you can!😁
They take the alu edge off and slide it in the frame, same for the panel. I've seen it yesterday. if this is ''custom'' then I guess yes, but it's literally the stage with out the alu frame and nothing else is different. Even the holes for the front cover are the same, inside it also has the two lights you see on the Stage.
I asked how to built the contour and that's what I was told and also could verify by seeing it 🙂
The spec says the TV has 4 HDMI input. Will the Beoremote control them?
Yes but in the pricelist I found that you could buy a Cheaper version of the Stage without the Frame, So you don need to throw out frames ;)
I'll ask him again. I guess dealer's are lacking all the information they need so far. I wonder if they can buy a Contour without the Stage though.
The "naked" Stage is featured in the pricelist as a stand alone item with its own product number, so I guess you can.
LG CX 48": 1.190€ (or 55" for 1.299€)
Where are you located? If you can get CX48 for 1.190 you can get the Contour for less too. In the Netherlands CX48 still retails for 1.699.
I'm located in Finland. Just checked the 48" CX price: https://www.verkkokauppa.com/fi/product/24134/nkfdh/LG-OLED48CX-48-4K-Ultra-HD-OLED-televisioIt's the time of year when CX prices (prices of LG's this year's models in general) start to come down as 2021 models are around the corner.Where are you located? If you can get CX48 for 1.190 you can get the Contour for less too. In the Netherlands CX48 still retails for 1.699.
