BeoVision Contour
moxxey wrote:
Emil Jensen wrote:
I would not buy a Beovision without these functions, at least not for my livingroom.
My point is/was, an increasing number of people won't or don't use them and controlling the TV direction from a remote really is a luxury not necessary on those low-end TVs. That's why they sit in that bracket. Almost no-one is going to connect a Horizon or Contour to a BL5.
I do agree PL is lacking and should have been added, but that's an issue with the Stage, but the rest for me - and many - are increasingly superfluous.
We have to remember, and we almost never do, that the BeoWorld audience is not your general B&O audience and B&O has to design accordingly to the wider market.
But in my experience most B&O users use their motorized stand, and have been used to it since the 90'
And yes it is a Luxury, but is that not the reason to buy a Beovision?
And the Harmony have only got a motorized stand now because of public demand.
So I really do not agree with you on this point.
Moxxey, I use a Beoremote one to fully control my Sky Q 2TB box via PUC on a BV11-55. I never use the sky remote which is actually put away in the attic. The BR One does everything..
I ask you a question: what should now be the right Beovision to replace a BV 8-40 with 5 connected beolabs (not BL5 ...)? The Contour would have been perfect in size and price. Or am I wrong ?
@mseverg68 : yes you're completely wrong as the Contour doesn't have any output for your 5 speakers. I'm also considering upgrading my BV8 40 with something better, hesitating between Harmony and Eclipse, but with a little 15-month child at home I think I might better wait some more years 😐
I can give you the exact opposite argument with the Eclipse which has now a fixed stand option because of public demand! Maybe there is approx 50% of users needing it and 50% that doesn't care! 😁
Give me a motorised stand or give me death.
moxxey wrote:
Sandyb wrote:
My Beoremote 1 controls my Sky Q box.....not sure what the issue is (unless I'm missing something)
Are you sure? How? The 4K Sky Q box is notorious for not being externally controllable. There was never a PUC option on my BV11 either (although there was for Sky HD).
What can you control? There's basic control via the TV, but I can't change channel, for example.
Sure as a sure thing. Sky Q box on my Eclipse since day 1 is controlled - with all functions excluding voice control - by onboard PUC. Super reliable as well.
diisign.com
So why not keep it as an option. Then b&o can serve all their customers. I had a motorized stand with my bv1, bv11 and now a motorized wall mount with my bv eclipse. And use it every day with the br1 under mybutton.
The BV Horizon didn’t came with a motorised floor stand, as the V1-40or BV8, and while the BV Contour has almost the aspect of a BV 11, it’s an entry-level Beovision so we’re accustomed of not seeing motorised stand for this category...
But the real issue is that the Contour is just a stage + LG 48 panel + a frame, so unfortunately, as for power link, there is no dedicated electronics inside it to control a stand 🙁
Yes very sure
I switched over from Sky HD to a Sky Q box 3 months ago, and my BR1 has the same control over the Q as it did over the HD box.
Not that I think the BR1 does the controls brilliantly, but it’s fine, and exactly the same for me as it was for the Sky HD box
I don’t think I changed the PUC table in my 12-65 and Avant when I got the Q installed, for the record
