BEOVISION AVANT
Hello,
I have one beovision avant 28 RF with a fantastic picture when connected with an analogic cable.   I've just just bought another 32 RF last version ( with MP3 DVD).
With this one, the picture with analogic cable  is not good whereas with freeview it's good but not so fantastic as the 28 RF with ordinary cable .
Do you think it's normal or has the TV got a problem ?
Hi, I have got a rf 32 and a friend has a rf 28 I think his picture is sharper than mine!  Are you using the same analog cable?  also if your splitting the aerial feed try a signal booster??
Please define not good? (as in poor signal)
cheers Nick
Thank you for your reply.
I use the same cable and I have a booster for the signal.
32 on the RF analog I also have a problem switching sound on some TV channel.
Try another source - DVD via SCART for instance. That will tell you if it is the picture or the tuner/connection.
The 28" is smaller than the 32". Therefore also sharper picture. Can it be that simple?
