beovision Avant 75 old and difference with New Generation
Don’t really get the operating system issues? Don’t we all just use SKY and ATV etc?
BV11 is never set to TV, just PS4, SKY and ATV. It has not even been connected to the aerial!
We also have a very modern LG, simply watch ATV.
Both work seamlessly with all.
xsanderr wrote:
Thank you all so much this was very helpful for me.
i have decided to purchase an 2015 first generation AVANT 75 with less hours on it. Putting my bv7 in the bedroom. Having a multi room system still working with master link radio, I am not sure if I will connect the master link radio system in the multi rooms or will choose for the beosound Core to use internet radio (podcast or spotify) on the Avant in the living room.
what can you recommend please, Core ore are  there better options?
have a great New Years Eve to all.
If the functions of the BS Core is what you’d need for multiroom, you could connect this to a free input on your ML audiosystem (which you obvisiously still have).
Hereafter you can listen to the sources of the Core on the ML and link the Core to the Avant (please ask, if you don’t know howto).
This solution is described in this thread:
/forum/general-discussion-and-questions/combining-ml-and-nl#post-2131172
and seems to fit your needs well.
By the way - there is Internet Radio built in to the Avant!
Hello MM
THX this is what my plan is to connect it on the ML system so I have a multiroom upstairs on my bv11
What i didnt like to have is putting the avant on and choose the source and switch it of later on when the Musik is playing. So I want a direct sound fi. When you put radio it directly plays internet radio source (whitout i have to Switch The tv off)
I suppose this is what you also mean?
xsanderr wrote:
Hello MM
You are now writing about a ‘bv11 upstairs’ - is that yet another tv, or did you mean the BV7-55, that you mentioned earlier???
Really everything you need to do is in the thread, that I linked to in the previous post!
Please describe your setup in detail - that is important for any further advice.
