Hi, the anti-reflection coating on the picture tube of my BV Avant 32 (2003/4 vintage) has annoying vertical purplish/rainbow streaks, probably caused by someone cleaning it with the wrong type of cleaner.
They are only visible in a dark room when a light shines onto the screen, or against dark images when the set is switched on. They are distracting, and I’d like them gone.
Has anyone any experience of how to remove them? I’ve tried most things to no avail, and it seems the only option left is to remove the plastic AR coating. If so, is it an easy job, is a razor blade the best kind of tool? Can the coat be left off (it’s an optional extra on the identical BV3-32 tube, so I guess so), or does it create an inferior picture?
Alternatively, can a dealer/technician fit a new AR coat.
Any comments gratefully received.
