No worries, we all pitch in where we can.
Once you’re in the play store you can scroll / go up to your account and in the apps you can set them to update automatically , if that’s a setting you would prefer.
If you’re trying to download the Netflix app it is most likely not going to work. You can download it but unfortunately you can’t use it. All the others I have tried have been solid.
If you prefer the android platform you could buy an Android TV dongle which has Netflix in it etc (the white one) and if you’re going to use chrome casting. It is built in but give it a go and see if you like it.
Appreciating that’s annoying as it’s preferable to work natively.
Or alternatively an Apple TV with PUC control - you may have one or several laying around 😂 you can use Netflix and a suite of apps.
I found that in the play store there was quite a few apps available.
I’m glad you were able to log in
Cheers
M
