Beovision AV9000 installation
Hi Sergi0,
I there any chance something wasn't seated perfectly when you assembled the screen and speaker?
Have the two elements been unjoined and reconnected since you first rebuilt it?
Julian
Beofan for many years with a penchant for 1990s audio systems.
Hi julian,
I did check but it wasn't that. I was able ro remove the part in picture and test it by directly powering it. the noise come from the transformers. I tried to find the same one but of course, it was not available.
I am trying to find the correct technical reference (220v in and 2x16v out - but I have no clue for the current) to replace it with a more modern one. That should be too complicated because I am working with an old school electronician.
cheers,
S.
I keep the thread open, that might be usefull for other.
I am going to the varnish solution right now. I read about it and it can't get worse doing so. I will unsolder the tranformer and immerge it in specific varnish. I will do that in a box where I can pump air to create a pressure for the varnish to get everywhere.
I'll post more details when I start the procedure !
If that does not work it might be an idea to look into if similar parts can be found in a TV from the MX series. These might be easier to find than an extra AV9000
Hi everyone,
I did repair the transfo. I used varnish 4226A. I follow chatGPT recommandation for its usage (gloves, etc...) and do it outside. I spray mutliple layer directly on the transfo. I remove it from the electronic PCB (desoldering). I let it dry for 96 hours and reinstall it. The vibration was gone, absolutely no sound anymore.
I can confirm that varnishing the transfo did work for me !
I put the transfo on a stacking system inside a tupperware. I spray on every side, wainting a little bit between spray. To dry it, I use another tuperware with padding absorber (like tissue) under the transfo. That helps me move it from outside to my cave. That wasn't as difficult as I thought, in fact it was super easy. The most difficult part was to do it outside as I live in an appartment...
Nice that you found a solution for the vibration issue :-)
Hope you can enjoy this beautiful tv now. I remember looking at the catalogs back in the day and using countless hours looking at the pages with the AV9000 setup with the Beolab 8000 and 6000.
This is a great update! I too remember oggling the AV9000 and trying imagine what films might sound like - I never had the pleasure of hearing a Pro-Logic surround sound film on one since.
Enjoy it @Sergi0 🙌
