Hi, if Lee can send you the woofer (which looks a lot like an Avant type anyway...if so i'd have some for you also :) ) maybe he can also send you the board at the back of the tube, with the focus potmeter on it.
Btw i'm assuming you're confident enough with tv-electronics to work on it....:).
Most likely your fuzzy screen is caused by a broken/bad focus-unit, ordering new would be the best of course but a donorpart might do for now...:).
Most likely all other picture (or rather: geometry-) problems are a matter of re-adjusting the geometry in the servine menu.
To get there, there are 2 pins on the Av board (with the scarts) close to the scarts, make a short shortcut and the tv will show the service menu.
With the beolink you can select and adjust values, exit (beo4) or tv to store and exit.
