The centre channel has stopped working on my Beovision 9 my front beolab 5’s work fine and my beolab 4000 rear speakers also work I’ve not changed any settings that I know off any help would be appreciated.
Beovision 9 sound problem
I was a BV9 owner along with BL9s but never came across this issue. The only thing I can think to suggest is a total system reset, so unplug all equipment and leave disconnected from the main for about an hour or so or even overnight. More than you need too, but that’s what I would probably try. You could double check the sound settings through the menu I guess although if you haven’t changed anything to date then I can’t see what more you could do. I am sure others with much more experience will chip in but for my part that’s all I can think I’d do in the same situation before contacting B&O for help. Best of luck.
Simon.
Were you playing a video source at a very high volume by chance? Unplug the TV and wait 45 seconds and then plug it back in. Does the center channel sound play now?
unplug the bv9 for 3 to 5 minutes. (the entire bv9 not just the bs3!) did you make changes to the bs3? check whether the center is plugged into the bs3 with powerlink.
it sounds like a failure in the ice power arm for the center channel. A friend has had a similar situation but his returns after unplugging the TV from the wall.
