Beovision 9 SKY HD Lip Sync
Hi
i have just had intalled a beovision 9 and a new Sky HD box and they are connected by HDMI and then Coax for the audio as HDMI does not give 5.1
I am having major issues with lip sync and its differant depending on the channel. i have played with the sky delay setting and it sort of works but its random..
Any ideas? Does anyone else have this issue?
 Andy
Hi
Do you mean component? What gives you the impression that HDMI cannot handle 5.1? Have you tried taking the component leads out of the equation?
Llewelyn
It can carry 8 channels of uncompressed digital audio!
Yes HDMI can do 5.1, uncompressed audio etc, but as far as I am aware there is a limitation of the Sky+HD box, as it can't do 5.1 over the HDMI.
As for the lip sync problems alot of people seem to be having them, the peps on the
No its purely that sky box does not send the 5.1 signal in HDMI they only send stereo so its not that HDMI does not do i know it does its just the cleaver people at sky dont use it for some reason..
I assume other people with vision 9 must have this issue, its fine with other things like my mac mini and DVB-t etc its just sky hd....
Its driving me mad and i have played with the delay setting on the sky box but i just cannot get it right.
Andy
