Hi There!
I have heard that a new BeoVision 9 Full HD (1080p) will be available shortly in Italy... can anyone one confirm that?
would be great to know the exact price as well...
Thanks a lot and regards from Florence!
Hi There!
thanks for the info... I understand this new Full HD version of the BeoVision 9 will be really available soon then... right ???
massimo
It will ship to customers starting July 17th. The price for the UK is as stated by Peter, but other European countries will see an increase in the range of €900 - €1.000.
Roger
Hi all,
i purchased a bv9 in june and now i know that it is delivered with full hd.
Do you know if it's possible to do an upgrade or if B&O can change the hd ready that i have with a full hd?
thx
I don't think it is unfortunately unless you want to replace the whole panel.
I wanted to buy the BV9 as well early this year but then decided to wait for the 1080p... i guess the difference is not noticeable though.
Hope this helps,
