BeoVision 9 Full HD
Hi There!
I have heard that a new BeoVision 9 Full HD (1080p) will be available shortly in Italy... can anyone one confirm that?
would be great to know the exact price as well...
Thanks a lot and regards from Florence!
No matter when you may be able to buy your Fully HD BeoVision 9, it will be your local dealer who will decide on the price that he/she will sell at, so I suggest you give him/her a visit at your local dealership.
There is no price increase for this upgrade.
thanks for the info... I understand this new Full HD version of the BeoVision 9 will be really available soon then... right ???
 massimo
It will ship to customers starting July 17th. The price for the UK is as stated by Peter, but other European countries will see an increase in the range of €900 - €1.000.
Roger
A price increase would have been rediclious if they did. The plasma panels full HD cost less then a WXGA plasmapanel a year ago!
thanks for the info guys... really appreciated... massimo
Hi all,
i purchased a bv9 in june and now i know that it is delivered with full hd.
Do you know if it's possible to do an upgrade or if B&O can change the hd ready that i have with a full hd?
thx
I don't think it is unfortunately unless you want to replace the whole panel.
I wanted to buy the BV9 as well early this year but then decided to wait for the 1080p... i guess the difference is not noticeable though.
Hope this helps,
Are you saying it is in fact possible to replace the panel?
