Beovision 9 and PS3
Hi Millemissen
Now I'm confused. Using a BR disc with DTS hd 7.1 and with the PS3 setting to LPCM the beovision 9 sound output says input pcm 7.1 - output multichannel 5 speaker
Setting to bitstream and the beovisoon 9 says input dolby 5.1 output dolby digital 5 speaker
So now I have to ask what is the difference with the two outputs and (as I have 5 speakers) which is best for me and why ?
I do want to get the best set-up I can
thanks wortonmiller
Hi wortonmiller,
we had a similar discussion in german forum a few days ago:
/forum/imported-unmapped/beocord-v8000-an-beovision-7-40-kein-recording
With a bluray (5.1 DTS-HD MA audio format) in my internal bluray player of BV 7-40 3D I can select the following in the settings of bluray player:
1. STANDARD
2. BITSTRAM
In case 1. I get INPUT AUDIO FORMAT: PCM 7.1, OUTPUT AUDIO FORMAT: MULTICHANNEL SPEAKER 5
In case 2. I get INPUT AUDIO FORMAT: DTS 5.1, OUTPUT AUDIO FORMAT: DTS SPEAKER 5
If you want to hear HD audio format, case 1. is the way to go. Ask "Millemissen", he is the real specialist!
But I have to admit that I cannot hear a real difference...
Regards
Räuber
Thanks Raeuber, I will have to test few more movies but like you i'm not hearing much difference between the two,  but I'm learning more :-)
One other thing to keep in mind - a minor point for sure - but if you let the Blu-ray player convert the audio internally, it will include the menu sounds and any commentary in the feed automatically. Otherwise, you would have to switch settings if you use the bitstream settings. I prefer to keep it simple and let my player convert audio all the time, and still have the quality of the high quality DTS and Dolby formats converted to PCM.
Good point,, thanks
Wortonmiller
