Hi all, new to the forum so please bear with me and my lack of technical knowledge.
I have just traded in my trusted Avant for a Beovision 8 32" I am more than impressed with the picture quality and sound.
However I have a slight technical problem that I and the two B&O technicians who installed the TV cannot resolve. I have searched the forum and found some good advice but still I am unable to resolve the cursed Wii set up. Hope you may be able to help.
On sound advice I purchased the Wii component cable and had this installed into my hidden multi cable routing behind the wall (mistake 1).🙁
On setting up the TV the Wii would not work at all using this cable, three coloured ends into the respective AV2 holes, the two audio coloured ends into AV2 scart utilising an adaptor. At most I could get sound but no picture.
It would work fine using the composite cable via the scart adaptor into AV2 scart.
I attempted to alter the Wii setting to HDTV using the composite cable, to no avail the option was visible but grayed out. Following a linked posting I tried to set the alteration up blind and then swapped cables (mistake 2)😭. This worked to a degree, but then all went wrong. Cutting a long and frustrating story short.... The Wii does not work at all now with either cable option, I can get sound but no picture.
I would be very grateful indeed for any suggestions ( falling short of smashing the Wii up) in the setting up of the funfilled device.
