Hi all!
Is it possible to have for example an audio source connected to a Beovision 8-40 (V.AUX) and then distribute it to a BeoLink Active?
Or does this require an AudioMaster or a B&O linkroom TV?
Hi all!
should work.
I have an iPod Touch on V.aux2 and this can be distributed over ML. The iPod is connected via Apple Composite Cable.
and you don't have any AudioMaster connected in the masterlink?
I had a BV 8-40 for test and I just tried the built in DVB-C from a BeoLink Active. It activated the speakers and then turned them off?
