Did you have any infos about hard drive for Beovision 7? that will be a nice upgrade in order to record TV, as seen in Loewe TV for example.
cheers,
sergio
cheers,
sergio
Yes there be a upgrade on BV7-40 also, here in sweden release in juni/july
And guys, there is a good point to have 40 inch in 3D......You can have it installed with a Projector that support 3D
Great with some news, but does no one have any more details, i.e. will the 7-40 be LED based now?
Will the modified BS3 be able to decode HD audio, and much more....
I did also hope for a 10-55 and a cheap entry TV, just a wish.
... more details, i.e. will the 7-40 be LED based now?
No
Any "inside" info if 3D will be introduced to the BV10 46"?
Thank you
Will these new TVs have a Beonet connector?
Will there be an option for an in-built 3D Blu-ray player for the Beovision 7-55 MK2 3D?
1) It's still based on a modified Beosytem 3 - no
2) yes
Going to be interesting to see what BR player they have put into BV7 now, I hope for B&O that it can decode HD Audio (DTS MA) and send the decoded signal to BS3.
And also how slow and noisy it is 😕
Will this also take effect in the North American market? I've seen nothing about this mentioned on the B&O website for North America. I was just getting ready to purchase a BV7-55. Looks like I better hold off and wait for the 3-D version!
Some quick from my dealer, beside the 3D and HDMI 1.4, the 7-55 will also get a new panel, going from 32 to 64 backlight zones, and a lot more diodes. No comment about DTS-MA, therefore this is probably a "no".
And a price increase for 7-55 by the way.
4-50 and 4-65 will be discontinued however.
... going from 32 to 64 backlight zones, and a lot more diodes...
the BV7/55 in it's MK1 version already has 8*12 = 96 backlight zones with 10 LEDs each segment
the MK2 version is going to have 16*32 = 512 zones with 6 LEDs per segment >> 3012 LEDs.
(more than 5 times as much zones as the current version and amount of the LEDs more than tripled)
