Beovision 7 placement/wires
Just make the outlets in the wall behind the BV7
Jos
There are also this LK-decor also possible to get one that can be placed over the wall socket
Hi Beowifi,
Do you have a set top box as well if so where have you placed it ?
Regards
Keith
If you are using a BeoLab 7.4 you should be able to combine all your wires into a cable sock and then cable-tie the sock to the floor stand. The way the 7.4 sits will then conceal anything which might otherwise be seen.
Doesn't solve the problems with the sockets, but it's how I've always dealt with the issue!
Hi Keith
I have all the wires in a sort of furniture, including PC, Xbox and HDR1
Regards
Jos
thanks for the link. placing order soon.
I must admit that it does look a bit like spegetti junction out the rear of our BV-7 32...but i am not going to any special lengths or expense doing anything about it as we will be moving house in the near future.
We still love it though!
