Beovision 7 picture and sound problems with SKY!
Hi Martin,
We have managed to get the sound and picture working! And in HD!
Now we do have one more problem. The problem is when ever we increase or decrease the volume of the TV we get this horrible beeping noise every time we touch it. Any ideas?
I really appreciate all of your help!
Best wishes,
Sam
Please tell us how you got it working.
You get a beep noise if you touch the metal frame of your tv ?
Hi All
I am servicing a Beovision 7 Screen and sound system and I'm having the problem mentioned in the above post:
"The problem is when ever we increase or decrease the volume of the TV we get this horrible beeping noise every time we change volume up or down. It is louder in the left channel than the right."
I have looked at all the audio signal cables and everything seems good. Any ideas how to fix the noise?
Karel
Sorry - pressed the wrong button and marked your post as an answer!
I think the buzzing when you change volume is related to the type of power link cable you are using - I had a similar issue with mine. Grab a replacement cable from Steve and see if that fixes it. For reference I was using a standard DIN cable - I'm not sure if it was a poor shielding issue or what, but when I replaced the cable the annoying buzz went away.
Hope that helps
