Beovision 7 floor stand with non-BO TV -- possible?
for those who only need a mechanical bracket with VESA
there are also solutions for mounting a TV on BV7-32 and BV7-40 stand
https://shop.oneremote.dk/shop/69109-tv-vaegbeslag-til-bo/
B&O started in the late '80's with the option to turn your LX or MX. Even then they integrated 3 presets which could be programmed/setup by the customer.
That later evolved with settings for maximun swing to the left and right for not hitting the walls.  The stand for the newer BV Avant was even more sophisticated. Alle these stands are not interchangeable.
Later this week I expect the arrival of my new scope/(investment you can say..), with different automatic decode functionalities. So, if someone is interested in my 4 year old Tektronix 1052B, just send a pm 🙂
The stand is a lot more complex than you would initially assume. All functions are controlled with just two control lines. It has a clever PWM feedback system feeding position back to the controller in the BV7, and a the same time it can be manually overridden. It also has a circuit preventing abuse and overload. It definitely not CAN driven (CAN is a balanced interface for automotive) nor I2C as you might have expected, the B&O HW engineers did it the old school way - from the ground up. It really is a magnificent design although highly complicated and expensive.
If you’re interested you can follow my “quest” to deliver a solution to what seems to be a recurring issue here:
link
A VERY long tread by the way… You might recognize some of the “characters” in a somewhat different setting.
It is in Danish for now, but Google is your friend, fell free to ask questions or add whatever knowledge you have along the way. Please note It will take some time to complete a universal and proven solution.
@PeterPan and @ BEOVOX141
thank you in the danish forum recordre.dk
strive to solve this "task".
I will probably not enter the forum, since the administrative pages are also Danish, and I need my friend GOOGLE to translate the threads.
So it would be good if you post here the results of your efforts.
@ BEOVOX141
By the way: I may look like FRANKENSTEIN :-), but it's only distantly related to Frankenberg ;-) lol
@ W.Frankenberg. I thought of Millemissen who translates Danish into German, for one he can.
But it just doesn't work. He wants to color the translations in his opinion. And we don't always agree. 😁
Look aside, this one keeps the tilt function whereas STB can only rotate.
W.Frankenberg 🤒
Here at BV 7-40 - floor-stand.
